CAD tip # 8940:
applies to: Inventor · |
Tip 14007: | Workaround for the missing (vlax-create-object) in AutoCAD LT (voice, clipboard, etc.) |
Tip 14006: | Universal MsgBox in AutoLISP. |
Tip 13163: | Blended transitional solid between irregular regions, circle-rectangle transition (3D in AutoCAD) |
Tip 12717: | How to hollow out a 3D solid body in AutoCAD? |
Tip 11228: | How to find the Revit version used to save a RFA/RVT file? |
How to change the +/- (plus-minus) symbol in dimension tolerances in AutoCAD Mechanical or MDT?
New layout view created by copying an existing one is always Off. « | » Using 3D models from 3ds Max for Direct3D applications in Windows 8.
