  Visitors: 9055
CAD tip CAD tip # 9630:
Inventor trick - conditional parameters (without iLogic)
A - answer Even without iLogic you can use a math trick in Inventor to set a parameter value based on a logical condition, depending on the value of another parameter.
Strictly speaking it is not about a logical condition, but rather about testing of divisibility by two, using the standard arithmetic operator modulo (%):
The expression:
v%2
returns 1 for odd values of v
and the expression:
(v+1)%2
returns 1 for even values of the parameter v.
By combining these two expressions you can form a "logical" conditional statement, which evaluates to H1 for odd values of v and to H2 for even values of v:
(v%2)*H1+((v+1)%2)*H2
Analogically you can extend this method also for other values but the resulting expression may get complicated fast.
Inventor
8.1.2014    10558×
Prices - CAD eShop:
applies to: Inventor ·
Tip 13852:How to bulk-update all model parameters?
Tip 13819:Position and docking of the Measure palette in Inventor 2024.
Tip 13744:Simple password protection of Inventor documents (iLogic).
Tip 13197:How to transfer a model or sketch parameter to iProperties?
Tip 12671:Import Excel table by snapping a photo of it.
