  Visitors: 5276
CAD tip CAD tip # 13288:
LayoutLF - automatic switching of group layer filters.
A - answer Using the freeware application, the reactor LayoutLF, you can automatically switch active layer filters (layer groups) according to the name of the current layout - when you switch layouts, it switches to the filter of the same name (if any).
You can download the LayoutLF application from the Download page and load it into AutoCAD using the APPLOAD command. The application doesn't need a user interface, the LAYOUTLF command just toggles the reactor on/off.
The auxiliar CreateFiltersByLayouts command will generate (pre-generate) empty filters based on the names of all the layouts in your drawing.
ACADADTACADMPlantMapCivil3D
12.4.2022    1051×
Tip 13442:How to easily count the number of certain objects in a DWG drawing in AutoCAD LT?
Tip 12215:How to change truecolor DWG objects to indexed ACI colors?
Tip 11054:Difference volume (3D solid) between two TIN surfaces (sets of coordinates)
Tip 10015:How to select and modify objects in ALL layouts of the DWG?
Tip 9721:Inverse layer filter - switching off all other layers.
