  Visitors: 6649
CAD tip CAD tip # 13183:
Lin2Cyl - bulk conversion of lines to 3D cylinders.
A - answer With the freeware utility Lin2Cyl and its command Lin2Cyl you can convert any selected line segments to 3D cylinders. Each segment will be converted to a cylinder oriented in space with a uniform specified radius and with cylinder bases at the end points of the original line segment.
The command Cur2Cyl available in the same utility also convert selected curves (polyline, spline, circle, ellipse, helix) to 3D tubes with a given radius/diameter.
Both commands can be obtained by loading the file Lin2Cyl.vlx, which can be downloaded from Download. Use APPLOAD to load the file into your AutoCAD.
ACAD
10.1.2022    7864×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 13040:iLogic - display information about complexity of an Inventor part.
Tip 12962:True 3D models of threads in Inventor 2024, 2023, 2022 and 2021.
Tip 12588:Which CAD formats can be be translated in Fusion 360 even without the cloud, offline?
Tip 11939:How to extract pipe centerlines from 3D point clouds?
Tip 11769:How to convert border lines (rails) to a surface?
VRMLout More info
