  Visitors: 10080
CAD tip CAD tip # 7090:
Line breaks in cells in AutoCAD tables.
A - answer If you want to enter a multi-line text in a table cell, you can either rely on the automatic "soft" line-wrapping (AutoCAD decides about line breaks) or you can type a "hard" line-break.
You can do this with the key combination Alt+Enter. This keyboard shortcut enters a new line code to AutoCAD table cells (similarly to Excel).
ACADLTADTMap
2.12.2009    19417×
Prices - CAD eShop:
Tip 12926:How to import point coordinates from Excel to AutoCAD?
Tip 12830:Converting pseudo-tables consisting of lines and texts to TABLE objects in AutoCAD DWGs.
Tip 12470:A table with calculated expressions is suddenly dead, doesn't calculate and update.
Tip 12118:Easy frames and tables in Revit text annotations. An undocumented trick.
Tip 11982:Creating table with parcel numbers and areas - AreaTab.
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
