  Visitors: 6301
CAD tip CAD tip # 7372:
Loading 3D models in the FBX format into AutoCAD.
A - answer AutoCAD 2011 contains two new commands for import and export of the FBX format files - FBXIMPORT and FBXEXPORT.
So you can import 3D objects from many public sources into AutoCAD. As an example - here is the NASA library containing 3D models of NASA satellites - NASA 3D models. Just start the FBXIMPORT command and choose the FBX file to load (do not load as a block).
ACAD2011
25.5.2010    18865×
Prices - CAD eShop:
applies to: AutoCAD 2011 ·
Tip 12884:How to insert your 3D model into a PowerPoint presentation?
Tip 12663:How to transfer my project from Infraworks to Revit?
Tip 12262:How to export a Maya LT scene to Autodesk Maya?
Tip 12233:How to compare two 3D mesh models and find differences/changes?
Tip 12029:How to print 3D characters designed in Autodesk Character Generator?
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
