  Visitors: 10364
CAD tip CAD tip # 8986:
Material density as a custom iProperty in Inventor.
A - answer Density for parts containing a single material type can be calculated from their mass and volume.
To add a custom iProperty containing the density value in your IPT file you can use the following simple iLogic macro:
density = iProperties.Mass/iProperties.Volume
iProperties.Value("Custom", "Density") = Round(density*1000*1000, 4) & " g/cm^3"
(omit the units suffix to use Density as a number)
Inventor2013Inventor2012
20.12.2012    9698×
Prices - CAD eShop:
applies to: Inventor 2013 · Inventor 2012 ·
Tip 13920:Saving your Inventor model in the presentation color scheme (iLogic).
Tip 13911:How to print all sheets at once from Inventor?
Tip 13884:How to send e-mails with an iLogic macro?
Tip 13852:How to bulk-update all model parameters?
Tip 13836:How to reset view numbering in Inventor?
