  Visitors: 6082
CAD tip CAD tip # 11914:
Maze generator for AutoCAD.
A - answer MAZE is a generalized maze generator written in VisualLISP. This utility was ported to AutoCAD from the original CLISP algorithm published on Github.
You can use MAZE to draw any maze structure - a predetermined arrangement of cells (a rectangular grid) with wall sites between them. Each new maze is unique, random. All generated mazes have a free walkthrough path (maze solution).
Download the free MAZE.LSP file from Download, load it into AutoCAD by mouse dragging or with the APPLOAD command and type the MAZE command to draw a randomly generated maze grid. The maze is drawn as LINE entities near the coordinate origin point (0,0).
You can change the values of the *width* and *height* LISP variables (in the LSP file) to draw mazes of any size (complexity). Always use odd numbers for these sizes.
Sample DWG drawings generated by MAZE are here - MAZE-139x77.DWG and MAZE-47x29.DWG (3D maze, by assigning width and thickness to polylines made from Maze lines).
MAZE source code - VisualLISP:
; CLISP Maze 20030311 by Joe Wingbermuehle - maze generator
; Mod from CLISP to VisualLISP by CAD Studio, 2018 - www.cadstudio.cz  www.cadforum.cz
; - like us on Facebook - fb.com/CADstudio
; The width and height of the maze. Both must be odd!
(setq *width* 39) ; 139
(setq *height* 21) ; 77
(setq maze nil)
(vl-load-com)
(defun C:MAZE ( / x y)
 (defun random (rng / x) ; integer version
  (fix (* (/ (setq x 4294967296.0 seed (rem (1+ (* 1664525.0 (cond (seed) ((getvar 'DATE))))) x)) x) rng))
(defun setf (arr x y new) ; put array
 (vlax-safearray-put-element arr x y new)
(defun aref (arr x y) ; get array
 (vlax-safearray-get-element arr x y)
; Start carving the maze at a specific location.
(defun carve-maze (x y / d c cd dv x1 y1 x2 y2)
	(setq d (random 4))
		(setq c 0)
		(while (< c 4)
         (setq  cd (rem (+ c d) 4) ; mod
                dv (cond
                        ((= cd 0) (list 1 0))
                        ((= cd 1) (list 0 1))
                        ((= cd 2) (list -1 0))
                        (t        (list 0 -1)))
                x1 (+ x (car dv))
                y1 (+ y (cadr dv))
                x2 (+ x1 (car dv))
                y2 (+ y1 (cadr dv))
            (if (and (and (> x2 0) (< x2 *width*))
                     (and (> y2 0) (< y2 *height*)))
               (if (and (= (aref maze x1 y1) 1)
                        (= (aref maze x2 y2) 1))
				  (progn
                     (setf maze x1 y1 0)
                     (setf maze x2 y2 0)
                     (carve-maze x2 y2)
		(setq c (1+ c))
      ); loop
; Generate a maze
(defun generate-maze ()
   (random 13)
   (setf maze 1 1 0) ; 1 1 0
   (carve-maze 1 1)
   (setf maze 1 0 0) ; maze entry
   (setf maze (- *width* 1) (- *height* 2) 0) ; maze exit
; Display the maze - textual
(defun display-maze ( / y x)
   (setq y 0)
   (while (< y *height*)
      (setq x 0)
      (while (< x *width*)
         (if (= (aref maze x y) 1)
            (princ "[]") ; \U+25AE
            (princ "  ")
		 (setq x (1+ x))
      ) ; wh x
      (terpri)
	  (setq y (1+ y))
   ) ; wh y
; Draw the maze - graphics
(defun draw-maze ( / y x elem e oldc oldo)
   (setq oldc (getvar "CMDECHO")  oldo (getvar "OSMODE"))
   (setvar "CMDECHO" 0)(setvar "OSMODE" 0)
   (setq y 0)
   (while (< y *height*); HORIZONTALS ----
      (setq x 0  elem nil)
			(if elem (setq elem (cons (list x (- *height* y 1)) elem)) ; still horizontals
					 (setq elem (list (list x (- *height* y 1))))
			) ; else 0
			(if (and elem (> (length elem) 1)) ; any segments to draw?
				(progn (command "_LINE" (car (reverse elem)) (car elem) "") (setq elem nil)) ; start->end
				(setq elem nil)
         ) ; maze draw
		 (setq x (1+ x))
		 (if (and (= x *width*) elem (> (length elem) 1))(progn (command "_LINE" (car (reverse elem)) (car elem) ""))) ;finish row
      ) ; wh x
	  (setq y (1+ y))
   ) ; wh y
   (setq x 0)
   (while (< x *width*); VERTICALS -------
      (setq y 0  elem nil)
			(if elem (setq elem (cons (list x (- *height* y 1)) elem)) ; still verticals
			) ; else 0
				(setq elem nil)
         ) ; maze
		 (setq y (1+ y))
		 (if (and (= y *height*) elem (> (length elem) 1))(progn (command "_LINE" (car (reverse elem)) (car elem) ""))) ;finish column
      ) ; wh y
	  (setq x (1+ x))
   ) ; wh x
  (setvar "OSMODE" oldo)
  (setvar "CMDECHO" oldc)
; Create and display the maze.
(setq maze (vlax-make-safearray vlax-vbInteger (cons 0 (1- *width*)) (cons 0 (1- *height*)))) ; create array
(setq y 0)
   (setq x 0)
      (setf maze x y 1) ; prefill
      (setq x (1+ x))
   ) ; wh x
   (setq y (1+ y))
) ; wh y
(generate-maze) ; create
(display-maze)  ; list out
(draw-maze)     ; draw out
(princ)
(princ "\nMAZE command loaded.")
(princ)
ACAD
9.6.2018    8389×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 12237:UnfoldRS - unfold 3D surfaces to 2D in AutoCAD.
Tip 12215:How to change truecolor DWG objects to indexed ACI colors?
Tip 12036:Sel2BlkRef (blockify) - replace repeating objects with block references
Tip 11511:Assigning elevations to 2D contours (isolines).
Tip 11502:How to detect DWG files created as an export from Autodesk Revit?
