  Visitors: 3036
CAD tip CAD tip # 6904:
Missing option "Include when adding sheets" in AutoCAD 2010?
A - answer If you have upgraded to AutoCAD 2010 from an older version (2009), you may miss the option "Include when adding sheets" (Model/Layout) in the dialog of the command PUBLISH.
The selection of model/layout tabs is now available directly in the file selection dialog when adding new sheets to publish. For existing sheets, you can control this setting in the context menu - after mouse right-click on the sheet name.
ACAD2010
3.9.2009    4646×
Prices - CAD eShop:
applies to: AutoCAD 2010 ·
Tip 11914:Maze generator for AutoCAD.
Tip 11898:Automatic schedule - number of blocks in a drawing.
Tip 11845:What is the difference between ShareDesignView (2017) and ShareView (2019) in AutoCAD?
Tip 11835:Shared Views to your DWG drawings - easy collaboration with collegues and clients.
Tip 11821:How to publish PDF sheets (pages) under the plain layout name?
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
