  Visitors: 1744
CAD tip CAD tip # 6942:
My AutoCAD does not display solid hatches and fills.
A - answer If your DWG drawing doesn't show solid hatches and fills in plan views, first of all check the FILLMODE variable.
If this variable is On and if other hatch types are displayed properly, the possible cause of this problem can be the visual style with hidden lines which you may have set inadvertently (see VISUALSTYLES or SHADEMODE).
To go to the plan view - in an unlocked Viewport type "PLAN" at the command line, select WORLD, hit Enter.
Another cause may be an incompatible graphics card or its driver.
ACADADTACADMCivil
17.9.2009    72244×
Tip 12633:Sol2SolH - convert DWG objects of the type Solid to Hatches
Tip 12287:AutoCAD hatch flood-fill does not honor all boundaries.
Tip 12105:Select the smallest DWG object - MinOf utility.
Tip 8996:Material-based hatch patterns in Inventor section views.
Tip 7728:Streaks in solid hatch fill in AutoCAD PDF files.
