  Visitors: 1484
CAD tip CAD tip # 7292:
New commands introduced in AutoCAD 2011.
A - answer You can find an overview of all, more than 100 new commands of AutoCAD 2011 (and also other AutoCAD versions) in the interactive dictionary of AutoCAD commands - see the section AutoCAD commands 2011 on this web.
This database contains both the documented and undocumented AutoCAD commands since R12 (plus LT commands and AutoCAD variables).
ACAD2011LT2011
6.4.2010    15022×
Prices - CAD eShop:
applies to: AutoCAD 2011 · AutoCAD LT 2011 ·
Tip 13938:ModDXF - utility for bulk modification/display of internal DXF properties in DWG entities.
Tip 13855:DBXscanLayers and DBXscanBlocks - bulk report content of DWG files in a folder.
Tip 13822:Fast layer visibility toggle ON/OFF.
Tip 13683:Limitations of the LISP language (AutoLISP, VisualLISP) in AutoCAD LT - what to watch out for
Tip 13675:Two PURGE commands in Autodesk Civil 3D.
