  Visitors: 13634
CAD tip CAD tip # 8942:
New layout view created by copying an existing one is always Off.
A - answer When copying viewports in a layout, the new viewport (view) is always off and has to be switched on manually (-VPORTS, option On, or in the Properties palette).
This won't be neccessary if the automatic drawing regeneration is on – the variable/command REGENAUTO has to be preset to On.
ACADLT
28.11.2012    4094×
Prices - CAD eShop:
applies to: AutoCAD · AutoCAD LT ·
Tip 12837:RenameCSV - rename layers, blocks, layouts, views, linetypes using Excel tables
Tip 12448:Pan view (change view target) in multiple viewports of a layout.
Tip 11608:Trim to rectangle - cut out a part of a DWG drawing.
Tip 10986:FATAL ERROR: Unhandled Access when displaying a layout with rendered view
Tip 10167:Keyboard shortcuts in Autodesk Fusion 360.
