  Visitors: 4457
CAD tip CAD tip # 10057:
No grips are displayed after selecting pipes.
A - answer After selecting a pipe in a model no grips are displayed, or the grips are displayed only in the "Wireframe" display mode.
This may be caused by the setting of the system variable CULLINGOBJ - it should be set to "0".
Please also check, whether grips are enabled in AutoCAD options – Options > Selection tab > check the option "Show Grips".
Plant
21.10.2014    11292×
Prices - CAD eShop:
applies to: AutoCAD Plant 3D ·
Tip 13878:SelectSimilar - extended selections for AutoCAD, incl. LT and Web versions
Tip 13688:How to select all DWG objects of a certain type in AutoCAD LT? (texts, circles...)
Tip 13340:Where is a given font used in my drawing?
Tip 12501:Dynamic associative array of elements along a curve.
Tip 12172:How to show or hide an object in all visibility states?
Automatic nesting of 2D parts on rectangular sheets in AutoCAD
AutoNEST 2008 More info
