  Visitors: 1165
CAD tip CAD tip # 8661:
Overview of files referenced from an Inventor drawing.
A - answer To quickly display a list of files referenced from an Inventor drawing, you can use the following simple VBA macro. Insert the "RefList" macro into your Inventor VBA Editor (Tools > Options > VBA Editor) and run it with Alt+F8.
Sub RefList()
Dim oDoc As Document
Dim Refs As String
Refs = ""
Set oDoc = ThisApplication.ActiveDocument
For i = 1 To oDoc.AllReferencedDocuments.Count
Refs = Refs & oDoc.AllReferencedDocuments.Item(i).FullDocumentName & vbCrLf
Next
MsgBox Refs, vbInformation, "Reference list"
End Sub
Inventor
31.5.2012    4744×
Prices - CAD eShop:
applies to: Inventor ·
Tip 12828:How to quickly delete 3rd party links to external objects in Inventor?
Tip 12815:How to fill iProperties into Inventor files from Excel?
Tip 12520:How to set Inventor Display style and Lighting style from an iLogic macro?
Tip 12392:Export unfolds of sheetmetal parts to DXF - parameters for iLogic and VBA
Tip 12136:Security settings for Inventor data files and add-on applications.
