  Visitors: 9091
CAD tip CAD tip # 13414:
Performance analyzer in AutoCAD 2023.
A - answer Since the release 2023.1, AutoCAD has integrated a new performance analyzer to help you find and diagnose any problems with the speed of certain operations or specific DWG objects. AutoCAD analyzes display operations with individual entities, file access speed, and other functions.
To launch the Performance Analyzer palette, use the PERFANALYZER command. This will display a palette from which you can start recording your operations. When the operation logging is completed, your operations are analyzed and the resulting diagnostic report is displayed. From it, you can determine possible causes and discover the sources of any AutoCAD slowdowns on your computer.
ACAD2023
15.7.2022    2954×
Prices - CAD eShop:
applies to: AutoCAD 2023 ·
Tip 13809:AutoCAD displays continuous lines and texts as dotted.
Tip 13737:Formatting leading zeros in AutoCAD fields (and automatic field update).
Tip 13633:How to run Revit, Inventor or Windows version of AutoCAD on macOS?
Tip 12117:The Ctrl+Shift+letter hotkeys do not work (e.g. Ctrl+Shift+C in AutoCAD)
Tip 12103:Random lines are displayed over my AutoCAD drawing.
