  Visitors: 4214
CAD tip CAD tip # 1003:
Interbase (V5/5.5/6) database tables opened from AutoCAD are locked exclusively - "Lock Conflict or no Wait Transaction" error.
A - answer You have to use other than standard ODBC database driver.
Either use OLE DB driver for Interbase (as of this time there is no version of OLEDB which will run correctly inside AutoCAD), or use a commercial ODBC driver by Easysoft (http://www.easysoft.com/products/interbase/main.phtml) - the only driver which currently (Feb-2001) runs fine in AutoCAD/Interbase environment.
ACAD2000Map2000
2.2.2001    5718×
Prices - CAD eShop:
