  Visitors: 7536
CAD tip CAD tip # 1451:
How to mirror a block with text when text should remain readable?
A - answer The MIRRTEXT variable has no influence here - if a text entity is part of a block definition, it is always mirrored, independently on the MIRRTEXT value.
If you want to have a readable text in a mirrored blok, define your text as a block attribute (ATTDEF) with a preset value - variable (non-constant) attributes are influenced by the MIRRTEXT variable.
ACAD
4.7.2001    61654×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 13948:Undocumented function for quick block attribute editing - directly edit an attribute.
Tip 13938:ModDXF - utility for bulk modification/display of internal DXF properties in DWG entities.
Tip 13878:SelectSimilar - extended selections for AutoCAD, incl. LT and Web versions
Tip 13855:DBXscanLayers and DBXscanBlocks - bulk report content of DWG files in a folder.
Tip 13831:ReplMTcol - recoloring parts of text in paragraph Mtext.
