  Visitors: 6673
CAD tip CAD tip # 1473:
Warning: Multiply owned object, index "nnnn"
A - answer This is a message about a duplicate internal pointer to a drawing object. Can result from an error in ARX add-on application or improperly released XRef or DWG coming from a non-Autodesk software.
In Mechanical Desktop, this may be result of a bug in externalized parts, and it can be ignored.
You can delete (erase!) the complaining object by entering:
(entdel(handent "MYHANDLE"))
on the command line (replace MYHANDLE with the hexadecimal code reported by the AutoCAD warning message).
To highlight the object before deleting it you can also use:
(redraw(handent "MYHANDLE")3)
ACADLTMDTCivil
12.7.2001    18020×
Prices - CAD eShop:
applies to: AutoCAD · AutoCAD LT · MDT · Civil 3D ·
Tip 821:Externalized part comes as invisible to an assembly.
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
