Printer model |
standard RAM |
max. RAM |
possible upgrade |
notes |
DJ 430/450/455/488 |
4 on board |
36 |
32 |
One free slot |
DJ 500 |
16 on board |
160 |
64/128 |
Necessary to buy the HP-GL/2 card to upgrade memory, the only memory slot is in the HP-GL/2 card. Upgrade memory distribution: 16MB base + 16MB fixed in HP-GL/2 card + SIMM (64or128MB) |
DJ 800 |
96 |
160 |
64/128 |
Memory distribution: 16MB fixed in motherboard+16MB fixed in formatter card +64MB SIMM in formatter card. Upgrade: Remove the 64MB SIMM and install a 128MB SIMM |
DJ 500PS |
16 |
160* |
64/128* |
*Possible to upgrade through the HP-GL/2 card like in the DJ500, although the HP-GL/2 card is not intended to be used with this model |
DJ 800PS |
160 |
No upgrade available |
DJ 1050C |
32 |
128 |
32/64 |
16MB DIMMs obsolete by 01/03/2000, supported until 03/2005 Current memory configuration: 1 32MB in one slot, one free slot. |
Upgrade to max: Change the 32MB DIMM for a 64MB DIMM, install an additional 64MB DIMM in the free slot Possible to find DJ1050C in the field with 16MB memory only |
DJ 5000 |
128 |
256 |
64/128 |
Two slots for memory, standard 1 128MB SIMM in one slot and one free slot. |
DJ 5000PS 60" |
192 |
256 |
64/128 |
Standard 1 128MB and 1 64MB SIMM. To upgrade, remove the 64MB and install a 128MB SIMM |
DJ ColorPro CAD |
44 |
76 |
32 |
2 memory slots Standard distribution: 4MB fixed on motherboard + 8MB fixed in PCL5 SIMM + 1 32MB SIMM installed Upgrade: Install a second 32MB SIMM in the free slot. |
DJ ColorPro GA |
4 on board |
68* |
32* |
*2 free memory slots, upgrade possible using ColorPro CAD SIMMs, but this printer is not intended to be upgraded |
DJ 700 |
5,5 |
69,5 |
32 |
5.5 MB on motherboard + 2 free slots |
DJ 750C |
7 |
71 |
32 |
7MB on motherboard + 2 free slots |
DJ 750C+ |
11 |
75 |
32 |
11MB on motherboard + 2 free slots |
DJ 755CM (A model) |
71 |
No upgrade. 7MB on motherboard + 2 32MB SIMMs standard |
DJ 755CM (B model) |
75 |
No upgrade. 11MB on motherboard + 2 32MB SIMMs standard |
DJ 2000CP |
8 |
68 |
32 |
2 memory slots. Standard distrib: 4MB in motherboard + 4 MB SIMM in 1 slot Upgrade: replace 4MB SIMM by 32MB SIMM and install additional 32MB SIMM |
DJ 2500CP |
36 |
68 |
32 |
2 memory slots standard distrib: 4MB in motherboard + 32MB SIMM (1 free slot left for an additional 32MB SIMM) |
DJ 3000CP |
12 |
68 |
32 |
2 memory slots. St distrib: 4MB in motherboard + 8MB SIMM in one slot. Upgrade: replace 8MB SIMM by 32MB SIMM and install additional 32MB SIMM |
DJ 3500CP |
36 |
68 |
32 |
DJ 2800CP |
8 |
68 |
32 |
Upgrade like DJ2000CP, but system is optimized to work with standard memory. Fiery RIP memory: 64MB, upgradeable ONLY on demand in case of technical problems |
DJ 3800CP |
12 |
68 |
32 |
Upgrade like DJ3000CP, but system is optimized to work with standard memory. Fiery RIP memory: 64MB, upgradeable ONLY on demand in case of technical problems |
