  Visitors: 5175
CAD tip CAD tip # 1605:
"Incorrect command line parameters" installation error.
A - answer Can occur when installing an Autodesk product on a system with Windows 2000 (SP1), NTFS disk and Novell Client v4.8.
Solution: install a MSI update - usually in \MSI\instmsiw.exe (eg. on AutoCAD 2002 CD); do not run setup.exe but install the product by running the .msi archive directly (e.g. acad.msi).
ACADLTVoloInventor
100% Win2000  CAD
9.9.2001    18319×
Prices - CAD eShop:
applies to: AutoCAD · AutoCAD LT · TrueView/VoloView · Inventor ·
Tip 13539:Revit 2023.1 shows "Twinmotion is not installed"
Tip 13263:Error when renaming assembly files in Design Assistant 2022.
Tip 12605:Script error (utag) when trying to log-in with your Autodesk ID.
Tip 11863:You cannot install this product on the current operating system.
Tip 11854:iLogic error in Inventor 2019: invocation of constructor threw an exception
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
