  Visitors: 1111
CAD tip CAD tip # 1737:
Older LISP programs are not working properly.
A - answer The LISPINIT variable with the default value 0 causes that LISP programs are not initialized (LISP variables not reset) in multiple drawings environment.
Try to set LISPINIT to 1.
ACADADTMapMDT
19.11.2001    6598×
Tip 12131:Error: no function definition: VLAX-ENAME->VLA-OBJECT or VLAX-VLA-OBJECT->ENAME
Tip 11924:Simple navigation - switching 3D views with your numpad.
Tip 11664:Which AutoCAD commands do exist also in the commandline (non-dialog) dashed version?
Tip 11354:Animate dyn.block parameters and dim.constraints in AutoCAD DWGs.
Tip 10955:Evaluate VBScript functions from AutoLISP.
Link your AutoCAD block attributes with Excel tables/sheets. Automatically. Dynamically. Bidirectionally.
Try Excellink 2015 More info
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
