CAD tip # 1739:
applies to: AutoCAD · |
Tip 14045: | In my AutoCAD script file (.SCR) I cannot enter a name containing a space. |
Tip 13977: | How to publish a PDF to the same folder as a DWG drawing in AutoCAD? |
Tip 13878: | SelectSimilar - extended selections for AutoCAD, incl. LT and Web versions |
How to measure Inventor parts without Inventor?
How to repair improperly coded texts in AutoCAD? How to replace %%236-type codes with normal characters? « | » Older LISP programs are not working properly.
