  Visitors: 8437
CAD tip CAD tip # 1764:
Cannot close drawing, command is active.
A - answer This error message can occur after using Browse in the Today window. Close the Today or Help windows and retry.
If you have several drawings opened (MDE), command can be active also in another (currently hidden) drawing.
Pending command can be also a result of an unfinished Diesel macro (cannot be distinguished visually) - try to press ESC several times in the complaining drawing.
ACAD2000LT2000
29.11.2001    13280×
Prices - CAD eShop:
applies to: AutoCAD 2000 · AutoCAD LT 2000 ·
Tip 13920:Saving your Inventor model in the presentation color scheme (iLogic).
Tip 13911:How to print all sheets at once from Inventor?
Tip 13836:How to reset view numbering in Inventor?
Tip 13822:Fast layer visibility toggle ON/OFF.
Tip 13737:Formatting leading zeros in AutoCAD fields (and automatic field update).
