  Visitors: 6148
CAD tip CAD tip # 1820:
How compatible are the so called "DWG-compatible" applications?
A - answer See the BUDWEISER benchmark DWG drawing by Xanadu/CAD Studio (BUDWEISER.DWG is downloadable from Download) as an example for testing of DWG compatibility. Load this DWG (AutoCAD 2000, 2004 or AutoCAD 2007, 2008, 2010, 2013 format) in any non-Autodesk CAD application and watch the differences.
True genuine DWG files are reported in AutoCAD as "TrustedDWG". Forged "DWG" files use only the same file extension but not the original file format. You can loose your design data with such incomplete reverse-engineered file formats.
ACADLT
13.12.2001    17115×   FAQ
Prices - CAD eShop:
applies to: AutoCAD · AutoCAD LT ·
Tip 13633:How to run Revit, Inventor or Windows version of AutoCAD on macOS?
Tip 13379:Revit failing on machines with multiple graphics cards.
Tip 13152:Compatibility of Autodesk products with Windows 11.
Tip 12555:Can I upgrade my CAD/PDM server to Windows Server 2019?
Tip 12103:Random lines are displayed over my AutoCAD drawing.
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
