  Visitors: 5160
CAD tip CAD tip # 1858:
Cutter is not engaged after my print job finished.
A - answer Some media have longer drying time between individual prints. Cutter is activated only after this drying period. But you can press Form Feed (Cut) on DesignJet plotter panel to cut your media.
The selected print quality also influences drying time. If you select fast draft from the quality pulldown menu, lines will be lighter a bit but plotting time will be alot faster and drying time eliminated.
100% *  PLT
4.1.2002    4707×
Prices - CAD eShop:
applies to: * ·
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
