CAD tip # 1961:
Tip 14056: | How to move blocks in the Z axis to the terrain model surface? |
Tip 13858: | Is there also a SETBYBLOCK command? |
Tip 13737: | Formatting leading zeros in AutoCAD fields (and automatic field update). |
Tip 13675: | Two PURGE commands in Autodesk Civil 3D. |
How to transfer your Plot style table to Excel?
How to import material library from AutoCAD to 3ds max/VIZ? « | » How to make universal/global macros - for any language version of AutoCAD?
