  Visitors: 5044
CAD tip CAD tip # 2023:
Is it possible to save Inventor 5.3 files to 5.0 format?
A - answer No, Inventor 5.3 has a different file format due to the use of a new modelling kernel - ShapeManager. But you can export/import assemblies in SAT or STEP formats.
It is of course possible to load 5.0 files to the 5.3 version (although we recommend to use the migration utility for this).
Inventor5
7.3.2002    6524×
Prices - CAD eShop:
applies to: Inventor 5 ·
Tip 13599:How to read iProperties from Inventor models and drawings in AutoCAD DWGs?
Tip 13513:How to quickly record a video from a CAD application or other Windows program? (replacing Screencast)
Tip 13505:How to find which version of Inventor has saved a file?
Tip 13263:Error when renaming assembly files in Design Assistant 2022.
Tip 13211:Automatic numbering/renaming of multi-volume bodies in a part.
