  Visitors: 4558
CAD tip CAD tip # 2039:
Command shortcuts not working when using DWG double-click.
A - answer Your command shortcuts ("C" for Copy, etc.) not working when you start AutoCAD session by double-click on a DWG file.
Your SUPPORT folder is probably not in your AutoCAD support files search path (see Options) or you have several ACAD.PGP files...
ACADLTMDT
14.3.2002    22560×
Prices - CAD eShop:
applies to: AutoCAD · AutoCAD LT · MDT ·
