  Visitors: 9019
CAD tip CAD tip # 2063:
How to open a drawing with write-protection (R/O)?
A - answer If you want to open a drawing (e.g. in LISP or in script) in a forced read-only (R/O) mode, you can use the following VLISP code:
(vl-load-com)
(defun openRO (fn)
 (vla-activate (vla-open (vla-get-documents (vlax-get-acad-object)) fn :VLAX-TRUE))
Then you can use e.g.:
(openRO "C:\\documents\\mydrawing.dwg")
or
(openRO (getfiled "Open R/O" "" "DWG" 0))
to open the drawing in ReadOnly mode (write-protected).
You can then also redefine the OPEN command to open all DWG files as read-only:
_UNDEFINE _OPEN
(defun C:OPEN()(openRO (getfiled "Open R/O" "" "DWG" 0))(princ))
and define a new command - "OPENEDIT" - to perform a "real" open:
(defun C:OPENEDIT()(command "._OPEN)(princ))
ACAD2010ACAD2008ACAD2004ACAD2000
26.3.2002    26953×   FAQ
Prices - CAD eShop:
Tip 13177:How to list Civil subassemblies used in the DWG file?
Tip 12914:Geo2GPS - GPS or UTM coordinates or web map from any coordinate of an AutoCAD DWG.
Tip 12837:RenameCSV - rename layers, blocks, layouts, views, linetypes using Excel tables
Tip 11780:How to rename layouts by a specific attribute of the title block?
Tip 11502:How to detect DWG files created as an export from Autodesk Revit?
