  Visitors: 5731
CAD tip CAD tip # 2096:
How to plot/print a .PLT file on a printer?
A - answer You want to print an existing .PLT (or .PRN) file on your printer (or plotter).
Make sure the file was created for your specific printing device (the same model). You can just copy the file to your printer:
COPY /B myfile.plt LPT1:
or
COPY /B myfile.plt \\server\designjet800
for a networked plotter.
If you have a networked plotter with TCP/IP interface enabled (e.g. HP DesignJet with HP JetDirect, firmware version 08.03 and higher), you can also use the LPR utility in WinNT/2000/XP (or Unix/Linux):
lpr -S192.168.0.99 -Praw -o l -d myplot.plt
where 192.168.0.99 is your plotter's IP address.
There are also several programs (freeware, shareware) for easier printing of PLT (or PRN) files from the Windows environment (e.g. PrintFile, GoPlot - see Download, etc.).
ACADLTInventorRevitADTMap
100% Win,Unix,Linux  CAD,PLT
15.4.2002    156165×   FAQ
Tip 9998:Automatically rotate drawings plotted from Revit or other software.
Tip 9855:Overview of postprocessors available in the CAM software Inventor HSM and Fusion 360.
Tip 6254:How to convert an AutoCAD DWG to CorelDRAW CDR file?
Tip 5728:GoPlot - batch plotting of PLT and PRN files.
Tip 5717:AutoCAD suddenly publishes multiple drawings to a single PLT file.
LogOff 2006 More info
