  Visitors: 4461
CAD tip CAD tip # 2207:
Interactive display of object properties.
A - answer Bubble for AutoCAD is a free utility for AutoCAD, AutoCAD LT, Map and Architectural Desktop (R14 up to 2006). In a bubble it displays detailed information about an entity you pause on with your cursor. It supports also AEC objects in Architectural Desktop and AccuRender and Map topology. Information about nested entities (blocks) can be displayed just by pressing the Ctrl key.
For download go to www.bubblecad.com/download.htm or Download
ACADLTADTMap
27.5.2002    6283×
Prices - CAD eShop:
Tip 12436:Faster 2-click balloon annotations in Inventor.
Tip 10406:Setting the bubble notification timeout in AutoCAD.
Tip 8263:AutoCAD Civil 3D does not display the surface tooltip bubble.
Tip 7764:Multileader with special framing.
Tip 7589:Import and export IGES files in AutoCAD (DWG).
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
