  Visitors: 5367
CAD tip CAD tip # 2219:
How to make an associative dimension of object's color, lineweight or Z-coordinate?
A - answer You can use the LiveLabel application (reactor) which dynamically links attribute or dimension text to a selected property of the source entity. You can also define conditional links.
E.g. to create a label with autoupdated elevation value (its own Z-coordinate): use/create any blok with at least one variable attribute, define a LiveLabel link style "Z-coordinate -> Block" and link a block reference to itself. Text attribute will always display the current Z-coordinate of your block reference (you can also use relative distances or other calculations using a Diesel expression modifier).
See LiveLabel.
ACAD2002ACAD2004ACAD2005ADTMDT
28.5.2002    8483×
Prices - CAD eShop:
Tip 5319:How to set two attributes in a block always to the same value?
Tip 4395:Quiet installation of Arkance Systems (XANADU, CAD Studio) applications.
Tip 3676:Advanced formatting of AutoCAD 2005/2006/2007 fields.
Tip 3666:Automatic level indicator for AutoCAD.
Tip 2688:How to limit the number of decimal places in automatic Area label from LiveLabel?
VRMLout More info
