  Visitors: 2495
CAD tip CAD tip # 2391:
61:05 error when printing on DesignJet 500.
A - answer This system error indicates a communication error. Please check the cable connection between the plotter and PC, retry the print job. Make sure you are printing the job over the right driver (in a proper format) - not a HPGL/2 job to a plotter with no HPGL card or a Postscript job to a plotter with no Postscript support.
ACAD
100% *  PLT,CAD
16.7.2002    42289×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 9285:HP Designjet 5500 shows error: 1f50011 boot failed.
Tip 3110:What is the 11:11 error code on DesignJet 500/800?
