  Visitors: 5038
CAD tip CAD tip # 2703:
How to import an IGES file in AutoCAD?
A - answer IGES format (.igs) import was included in older versions of AutoCAD. In newer versions (2000/2002) you had to buy the Autodesk Data Exchange module (IGES Translator) for IGES file import/export.
Current versions of the IGES Translator are part of the "mechanical" versions of AutoCAD - AutoCAD Mechanical (since R6) and Mechanical Desktop (or Inventor).
Since AutoCAD 2012 (2011 with Advantage Pack), the IGESIMPORT is a standard internal command in AutoCAD.
ACADACADM
27.11.2002    56402×
Prices - CAD eShop:
applies to: AutoCAD · AutoCAD Mechanical ·
Tip 13173:How to convert projection of a 3D model to a 2D DXF drawing?
Tip 12644:How to identify parts and assemblies imported from STEP/IGES?
Tip 12588:Which CAD formats can be be translated in Fusion 360 even without the cloud, offline?
Tip 12297:Which CAD formats are supported in the Autodesk Manufacturing Data Exchange Utility?
Tip 12184:Overview of CAD formats supported in Inventor 2020 (import/export/AnyCAD).
