  Visitors: 4585
CAD tip CAD tip # 2791:
Undocumented AutoCAD command (plotstamp).
A - answer If you need to run the dialog version of the PLOTSTAMP command even in your script files, menus and LISP applications, use its undocumented version _DDPLOTSTAMP.
ACAD2002LT2002MDT6ADT3
20.1.2003    11679×
Prices - CAD eShop:
Tip 12201:Quick dynamic measuring of objects near your cursor.
Tip 12118:Easy frames and tables in Revit text annotations. An undocumented trick.
Tip 12049:AutoCAD display (status bar) jumps and flickers while zooming.
Tip 11841:How to set output folder for AutoCAD plot to file?
Tip 11794:Undocumented code in field expression - MText contents without control characters.
Link your AutoCAD block attributes with Excel tables/sheets. Automatically. Dynamically. Bidirectionally.
Try Excellink 2015 More info
