  Visitors: 6962
CAD tip CAD tip # 2973:
Error [16.1.7] when starting AutoCAD.
A - answer This license management error can occur when you have not enough access rights to run AutoCAD (at least Power User up to Release 2002) or to write to the C-Dilla folder or when anti-virus software was running by the time you installed AutoCAD.
On Windows XP PCs also try to switch off the 'Use Simple File Sharing' setting in My Computer, Tools, Folder Options, View, Advanced Settings.
For Windows XP, install the latest version of C-Dilla RTS (Download).
You may need to reinstall your CAD application after applying these fixes.
ACADLTVIZMapInventorMax
11.4.2003    29231×
applies to: AutoCAD · AutoCAD LT · VIZ · AutoCAD Map 3D · Inventor · 3ds Max ·
Tip 6951:Can I legally use a second copy of AutoCAD on my other PC?
Tip 4701:What SafeCast versions are used by AutoCAD?
Tip 3862:License error [11.1.6020]
Tip 3470:How to transfer an Autodesk license to another computer?
Tip 3425:Is it neccessary to re-authorize AutoCAD after uninstall/reinstall?
LogOff 2006 More info
