  Visitors: 6321
CAD tip CAD tip # 3030:
How to convert a 3D perspective view to a 2D drawing?
A - answer You can plot out your 3D view to a .DXB file and then read it back using the _DXBIN command.
For true 3D solids you can also use the SOLDRAW command.
ACAD
5.5.2003    22559×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 8518:2D views and sections of a 3D solid in AutoCAD.
Tip 4123:How to make standard 2D drawings from AutoCAD 3D solids?
Tip 1659:How to convert a hidden-line view into lines and polylines?
