  Visitors: 7772
CAD tip CAD tip # 3088:
How to set the drawing window background color from menu, script or LISP?
A - answer Use the Background AutoCAD environment variable (not system variable) to change model window background color - e.g.:
(SETENV "Background" "1111111")
or (in LT):
_SETENV Background 1111111
and restart your drawing window (e.g. by switching to a layout and back).
Similarly you can change the layout (paperspace) background color with:
(setenv "Layout background" "123456")
Do not forget to specify the color code as a string and type the variable name verbatim as specified above (upper/lowercase).
The color code is calculated as:
(blue * 65536) + (green * 256) + red
You can get the current code by:
(getenv "Background")
ACADLTADTMapMDT
9.6.2003    12495×
Prices - CAD eShop:
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
