  Visitors: 13021
CAD tip CAD tip # 3247:
How to save an AutoCAD 2004 drawing to the R14 DWG format?
A - answer Use the 'Autodesk Batch Drawing Converter' or the 'Autodesk DWG TrueConvert' utility, which can convert drawings between the DWG14 (plus R13/R12/R10 and older), DWG2000 and DWG2004/2005/2006 formats.
For download at www.cadstudio.cz/download.
ACADLT
11.8.2003    15637×
Prices - CAD eShop:
applies to: AutoCAD · AutoCAD LT ·
Tip 12392:Export unfolds of sheetmetal parts to DXF - parameters for iLogic and VBA
Tip 10487:How to save a DWG/DXF in older format from AutoCAD 360?
Tip 9331:What is contextual field and why it is not updated in a block?
Tip 8675:Since which version does AutoCAD import Inventor IPT/IAM files?
Tip 7347:Batch convert DWG drawings to an older file format.
