  Visitors: 10021
CAD tip CAD tip # 3297:
How to print .PLT file to a local or network printer in Windows?
A - answer There are several ways to do this using the "COPY /B" command in a DOS window.
To perform this function easily you can use Govert's Drop&Print utility and just drop your .PLT file on any Windows printer (incl. networked or USB-connected).
For download see Download
ACAD
100% *  CAD,PLT
17.9.2003    35714×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 9998:Automatically rotate drawings plotted from Revit or other software.
Tip 9855:Overview of postprocessors available in the CAM software Inventor HSM and Fusion 360.
Tip 6254:How to convert an AutoCAD DWG to CorelDRAW CDR file?
Tip 5728:GoPlot - batch plotting of PLT and PRN files.
Tip 5717:AutoCAD suddenly publishes multiple drawings to a single PLT file.
