  Visitors: 8374
CAD tip CAD tip # 3414:
How to quickly create a series of layers?
A - answer Start the Layer manager dialog (version 2004 and higher) and repeatedly press the Enter key. AutoCAD creates automatically a new layer on every key press. Layers are named sequentially - Layer1, Layer2, ....
If you select a particular layer before pressing Enters, the newly created layers will inherit properties (color, on/off, etc.) of the selected layer.
You can also take a predefined set of layers from an inserted block or from a drawing template.
ACAD2004LT2004
13.11.2003    26011×
Prices - CAD eShop:
applies to: AutoCAD 2004 · AutoCAD LT 2004 ·
Tip 10921:The tolerance frame is displayed or printed in different line weight.
Tip 9721:Inverse layer filter - switching off all other layers.
Tip 8151:Keyboard shortcuts in AutoCAD for Mac.
Tip 7779:Unreconciled New Layers notifications.
Tip 7570:Print XREF entities faded.
