  Visitors: 6496
CAD tip CAD tip # 3555:
Problems opening a .DWG file in AutoSketch.
A - answer AutoSketch 8 is compatible with WinXP and with AutoCAD 2000x DWG files. But DWG2004 format is not supported. If you have DWG 2004 files you would need to resave them in the older "2000" format (DWG or DXF).
Please note that AutoSketch doesn't support PaperSpace so your DWG have to use ModelSpace for drawing entities.
AutoSketchACAD
26.1.2004    14696×
Prices - CAD eShop:
applies to: AutoSketch · AutoCAD ·
Tip 5299:Free conversion of old SKD files.
Tip 4447:What are the differences between QuickCAD and AutoSketch?
Tip 3339:AutoSketch reports "Can't find Row 1 in Table 12".
Tip 1093:How to save AutoSketch R7 drawings for older versions of AutoSketch?
Tip 117:What applications can create DWF files?
