  Visitors: 3949
CAD tip CAD tip # 3558:
How to transfer a Tool Palette between two computers?
A - answer In the CUSTOMIZE command, on the Tool palettes tab, export the selected palette using the Export function (rt-click menu) to a .XTP file.
Complementary, on the target PC, use the Import button to read in this XTP file with the toolpalette definition.
For AEC palettes in AutoCAD Architecture use mouse-dragging with the Content browser (AecContentBrowser).
ACAD2007ACAD2004LT2004ADTMap
26.1.2004    17852×
Tip 12215:How to change truecolor DWG objects to indexed ACI colors?
Tip 10365:Coordinate Tracker vs. Track Coordinates - how to track XYZ in Civil3D?
Tip 10139:Physical units conversion tool in an AutoCAD palette.
Tip 10015:How to select and modify objects in ALL layouts of the DWG?
Tip 9625:How to color 3D topo surface model by slope?
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
