  Visitors: 8973
CAD tip CAD tip # 3575:
Undocumented options of the 3DCONFIG command.
A - answer In the _3DCONFIG command of AutoCAD 2004 (and higher) you can enter "V" (_V, as adVanced) on the first command prompt. You will enter a more detailed 3D display settings mode.
ACAD2004ADT2004Map2004
30.1.2004    12991×
Prices - CAD eShop:
Tip 12201:Quick dynamic measuring of objects near your cursor.
Tip 12118:Easy frames and tables in Revit text annotations. An undocumented trick.
Tip 12049:AutoCAD display (status bar) jumps and flickers while zooming.
Tip 11841:How to set output folder for AutoCAD plot to file?
Tip 11794:Undocumented code in field expression - MText contents without control characters.
