  Visitors: 12945
CAD tip CAD tip # 3576:
Is it possible to develop AutoCAD add-on applications in Java?
A - answer Yes. Java is not an Autodesk supported platform but you can use a couple of methods to develop Java add-on applications for AutoCAD.
AutoCAD ActiveX® object model (COM) can be used in Java (and Delphi and other) environments.
AJaX Extension is an OpenSource project to integrate Java2 Virtual Machine (JVM) into AutoCAD (also supports Python) - see www.brainon.ch/AjaX/
ACAD
2.2.2004    7175×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 13512:How to open Google Earth directly in your AutoCAD window?
Tip 12605:Script error (utag) when trying to log-in with your Autodesk ID.
Tip 10709:How to create a profile from imported XYZ points in Fusion 360?
Tip 9855:Overview of postprocessors available in the CAM software Inventor HSM and Fusion 360.
Tip 5554:How to convert a CMYK color to RGB?
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
