  Visitors: 5529
CAD tip CAD tip # 3599:
Setting up STEP conversion between different MCAD applications.
A - answer On the ProSTEP iViP [url verified 2/2004] web server you can find detailed information about procedures and settings for data conversion (import/export) in STEP format between the most popular CAD systems (AutoCAD/Mechanical Desktop, Autodesk Inventor, Catia V4/5, I-DEAS NX, OneSpace Designer, Pro/ENGINEER, Unigraphics NX).
ACADMDTInventor
12.2.2004    13990×
Prices - CAD eShop:
applies to: AutoCAD · MDT · Inventor ·
Tip 12884:How to insert your 3D model into a PowerPoint presentation?
Tip 12609:Dynamo - how to convert a raster photo to 3D model in Revit?
Tip 12588:Which CAD formats can be be translated in Fusion 360 even without the cloud, offline?
Tip 12464:How much water is boiling in the Utah teapot?
Tip 12297:Which CAD formats are supported in the Autodesk Manufacturing Data Exchange Utility?
