  Visitors: 3531
CAD tip CAD tip # 3624:
How to convert 3D models from Architectural Desktop to Autodesk Inventor?
A - answer If you need to import models from ADT in Inventor as assemblies, you can use the following method.
In Architectural Desktop 2004 (and higher) or in ADT 3.3 with the Productivity Extension switch to a 3D view and use the ConvertTo3dSolids command to convert your 3D objects. Erase the original AEC objects. Save (export) the converted drawing to an AutoCAD format (Save as), not to the default ADT format.
Such .DWG drawing can be then opened in Autodesk Inventor and 3D solids can be selected for import.
ADT33ADT2004ADT2005Inventor
28.2.2004    25629×
Tip 13040:iLogic - display information about complexity of an Inventor part.
Tip 13013:Converting a 3D mesh to a 3D solid in Fusion 360.
Tip 13006:Calculated property descriptions (tobogan slide from floor to floor)
Tip 12962:True 3D models of threads in Inventor 2022 and 2021.
Tip 12938:How to convert a point cloud to a textured 3D model?
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
