  Visitors: 979
CAD tip CAD tip # 3652:
How to perform "Match Properties" for AEC objects?
A - answer To copy AEC properties in Architectural Desktop you can use the Tool palettes (object+properties from a tool palette).
Right click on a tool in a palette > Apply Tool properties to... and select the target (modified) object in your drawing.
ADT2004
9.3.2004    10088×
Prices - CAD eShop:
Tip 14048:List of disks, CD-ROM drives, USBs and other disk functions for LISP.
Tip 14039:How to display the total volume or surface of 3D solids in DWG?
Tip 14033:Clipping blocks, images, curves, xrefs - everything, into any shape
Tip 13996:Automatic hide for Revit palettes - save screen space (undocumented).
Tip 13963:Sum of pipe element lengths in Inventor (iLogic).
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
