New CADforum look launched.
Over 1.082.000 registered users (EN+CZ). New 1D nesting and 3D nesting tools, updated Color converter. New AutoCAD 2025 commands and variables. Learn about twiGIS.
CAD tip # 3682:
Question
Contents of the individual layers (objects) in a drawing can be splitted 'by layer' and exported to individual DWG files (with single layer) using the free LISP utility by CAD Studio - Lay2Dwg. For download on Download.
Just load the application with APPLOAD and start the LAY2DWG command. The command prompts for an optional filename prefix and then exports the contents of individual layers (or a given layer only) to separate DWG files.
You can enter layer lists in the form ("LayerA" "LayerB")
ACAD2007ACAD2000
23.3.2004
39737×
applies to: AutoCAD 2007 · AutoCAD 2000 ·
![CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products [www.cadforum.cz] CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products [www.cadforum.cz]](../common/arkance_186.png)
