  Visitors: 8804
CAD tip CAD tip # 3700:
What are the AutoCAD .CHX files?
A - answer CHX (CHecKStandards) are configuration files for the AutoCAD check standards functionality. They are used in the Batch Standards Checker utility (AutoCAD 2002 and higher).
ACADADTMap
30.3.2004    6602×
Prices - CAD eShop:
Tip 13735:My initial login to Fusion 360 isn't working.
Tip 13557:How to create an image with transparent background in Fusion 360?
Tip 13296:How to correctly load a KML/KMZ file into Civil or Map 3D?
Tip 13246:I can't copy/paste a block from AutoCAD into an Inventor drawing.
Tip 13082:PDF published from AutoCAD shows blurred lines.
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
